Salt-Lake Tyres
Salt-Lake Tyres
Pretty much, i sandwiched a tyre between two wheel-backs from a 50 Oldsmobile kit and sanded them on the dremel using a couple of small nuts and a bolt. You could just as well use washers.
I sand off all the tread first.
Then do the shaping.
Re: Salt-Lake Tyres
Impressive, clever idea using the wheel backs to clamp and hold the tyre.
Your dremel sure does get a work out :lol:
Re: Salt-Lake Tyres
Luke wrote:Impressive, clever idea using the wheel backs to clamp and hold the tyre.
It's starting to go on me. Half the time it ignores the fact I've flicked it on, and the other half of the time it runs so super-slow. Got a few years outta it :lol:
Re: Salt-Lake Tyres
My old dremel started to do that, when it packed it in, I gave it to my boss as I bought a new one anyway... he pulled it apart and found it just needed a clean INSIDE the casing... worked fine for him until he blew it up.
Re: Salt-Lake Tyres
Good stuff, I've found slipping the tyre over a socket does the trick as well ;)
